跳转到主内容
Lenovo Ideapad 330-15ARR Fan Assembly Replacement
你所需要的
  1. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 步骤 2 中的图像 1,2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 步骤 2 中的图像 2,2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: 步骤 3 中的图像 1,2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: 步骤 3 中的图像 2,2
    • Unscrew all three captive screws attaching the heat sink to the motherboard with a Phillips #0 screwdriver.
    • These screws stay attached to the heatsink, so do not attempt to remove them.
  4. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 步骤 4 中的图像 1,2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 步骤 4 中的图像 2,2
    • Remove the three Phillips #0 screws securing the fan assembly.
  5. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 步骤 5 中的图像 1,3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 步骤 5 中的图像 2,3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: 步骤 5 中的图像 3,3
    • Take the wires in your hand, and firmly but gently pull it out of its port.
    • Lift the fan assembly out of the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 20
总计 320
