跳转到主内容
  1. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Heat Sink Replacement: 步骤 2 中的图像 1,2 Lenovo Ideapad 320-17IKB Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Heat Sink Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Heat Sink Replacement: 步骤 4 中的图像 1,2 Lenovo Ideapad 320-17IKB Heat Sink Replacement: 步骤 4 中的图像 2,2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Battery: 步骤 5 中的图像 1,2 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Heat Sink Replacement: 步骤 6 中的图像 1,2 Lenovo Ideapad 320-17IKB Heat Sink Replacement: 步骤 6 中的图像 2,2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Fan: 步骤 7 中的图像 1,2 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Fan: 步骤 7 中的图像 2,2
    • Remove five 7mm Phillips #00 screws from the cooling fan.
  8. Lenovo Ideapad 320-17IKB Heat Sink Replacement: 步骤 8 中的图像 1,3 Lenovo Ideapad 320-17IKB Heat Sink Replacement: 步骤 8 中的图像 2,3 Lenovo Ideapad 320-17IKB Heat Sink Replacement: 步骤 8 中的图像 3,3
    • Gently lift the fan assembly out of the laptop.
    • Gently remove the connecting wires from the exterior of the fan by slowly "weaving" the cord between the ridges of the fan.
  9. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Heat Sink: 步骤 9 中的图像 1,3 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Heat Sink: 步骤 9 中的图像 2,3 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Heat Sink: 步骤 9 中的图像 3,3
    • Gently lift and remove the heat sink and set it aside.
结论
Kristen Gismondi
于2014年11月12日注册
64,922 信誉积分
创作了163篇指南
团队
iFixit iFixit 的会员
Community
148 名成员
创作了15,462篇指南
一条评论
Guys, did you notice the hole in the heat sink just above the processor? Doesn't it make the heatsink less effective?
Neeraj - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 11
总计 266
