你所需要的
Remove fourteen 7mm Phillips #00 screws from the back panel.
即将完成!
结论
另外一个人完成了本指南。
一条评论
Very helpful instructions. However, Step 6 indicates that you should remove 5 screws, but really you only need the 2 on the left that are actually connecting the fan to the system board, the rest are unnecessary. In fact, the machine I replaced this on only had the one screw in the top-left.
