跳转到主内容
加入维修社区 - 创建账户
Lenovo Ideapad 320-15IAP Battery Replacement
你所需要的
  1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo Ideapad 320-15IAP Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
  2. Lenovo Ideapad 320-15IAP Battery Replacement: 步骤 2 中的图像 1,1
    • Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Remove the CD drive.
  3. Lenovo Ideapad 320-15IAP Battery Replacement: 步骤 3 中的图像 1,1
    • Lift up the cover using the opening tool on different spots along the side of the laptop.
  4. Lenovo Ideapad 320-15IAP Battery Replacement: 步骤 4 中的图像 1,2 Lenovo Ideapad 320-15IAP Battery Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
  5. Lenovo Ideapad 320-15IAP Battery Replacement: 步骤 5 中的图像 1,2 Lenovo Ideapad 320-15IAP Battery Replacement: 步骤 5 中的图像 2,2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Ideapad 320-15IAP Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the battery.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 35
总计 1,890
