简介
In this guide, we will be replacing the screen of the Lenovo Ideapad 320-15ABR.
你所需要的
Begin by prying off the black cover surrounding the screen by wedging the the iFixit opening tool underneath it. Work your way down until you reach the hinge cover.
Insert iFixit opening tool in to the hinge cover as pictured and begin slowly prying it off.
Remove the black cover.
即将完成!
结论
3等其他人完成本指南。
The hinge cover does not come off as described. The small plastic tabs that hold it in place are interlocked. You remove the hinge cover by sliding it to the right about 1/8th inch otherwise you will likely break some of the tabs. This requires further disassembly first as the top frame does not provide the space needed to slide the hinge cover over. You must first remove the display assembly from the base.
hall999999 - 回复
