跳转到主内容
Lenovo Ideapad 320-15ABR Hard Drive Replacement
你所需要的
  1. Lenovo Ideapad 320-15ABR Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 2 中的图像 1,3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 2 中的图像 2,3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 3 中的图像 1,2 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 4 中的图像 1,3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 4 中的图像 2,3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 5 中的图像 1,3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 5 中的图像 2,3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,2 Lenovo Ideapad 320-15ABR Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 2,2
    • Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Gently lift up the hard disk from the left.
  7. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 7 中的图像 1,3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 7 中的图像 2,3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 7 中的图像 3,3
    • Do not lift hard drive straight up as it risks breaking the connection port.
    • Carefully pull the hard drive away and out of the connection port.
    Sir, and how to fix ssd after removing hdd in it.
    Zikrullah Ansari - 回复
  8. Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 8 中的图像 1,3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 8 中的图像 2,3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: 步骤 8 中的图像 3,3
    • Detach the bracket from the hard drive by pulling the bracket edges apart.
结论
25等其他人完成本指南。
4条评论
What is the maximum thickness of the replacement Hard Drive/SSD.
Drew Howden - 回复
It takes a standard 2.5” laptop HDD/SSD. They do not vary in thickness.
TheSolderSnake -
@TheSolderSnake You might want to use google to see the variation in 2.5” laptop drive thickness before making such a confident statement. ;)
Ben - 回复
This is gonna be fun! lol. I’ll be doing this in 5-15 minutes. Wish me luck!!!
Paul Hucik Jr - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 39
过去 30 天: 207
总计 23,752
