跳转到主内容
Lenovo Ideapad 320-15ABR Fan Replacement
你所需要的
  1. Lenovo Ideapad 320-15ABR Fan Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 2 中的图像 1,3 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 2 中的图像 2,3 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 2 中的图像 3,3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 3 中的图像 1,2 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 4 中的图像 1,3 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 4 中的图像 2,3 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 4 中的图像 3,3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 5 中的图像 1,3 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 5 中的图像 2,3 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 5 中的图像 3,3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Fan Replacement, Battery: 步骤 6 中的图像 1,1
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  7. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 7 中的图像 1,2 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 7 中的图像 2,2
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  8. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 8 中的图像 1,1
    • Remove the battery.
  9. Lenovo Ideapad 320-15ABR Fan Replacement, Fan: 步骤 9 中的图像 1,2 Lenovo Ideapad 320-15ABR Fan Replacement, Fan: 步骤 9 中的图像 2,2
    • Disconnect black and grey wires by simply giving them a light tug.
  10. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 10 中的图像 1,1
    • Remove the 6mm Phillips #1 screw connecting the fan to the laptop.
  11. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 11 中的图像 1,3 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 11 中的图像 2,3 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 11 中的图像 3,3
    • Lift the fan slightly and straight upward and unwind the black and grey wires from the fan.
  12. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 12 中的图像 1,1
    • Identify the red, black, yellow, and brown wire coming from the back of the fan connecting to the motherboard with a white connector piece.
  13. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 13 中的图像 1,2 Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 13 中的图像 2,2
    • Slowly pull and wiggle the white connector piece until it comes loose from the laptop.
  14. Lenovo Ideapad 320-15ABR Fan Replacement: 步骤 14 中的图像 1,1
    • Replace the new fan.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 46
总计 5,174
