跳转到主内容
Lenovo Ideapad 320-15ABR Battery Replacement
你所需要的
  1. Lenovo Ideapad 320-15ABR Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 2 中的图像 1,3 Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 2 中的图像 2,3 Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 2 中的图像 3,3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 3 中的图像 1,2 Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 4 中的图像 1,3 Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 4 中的图像 2,3 Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 4 中的图像 3,3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 5 中的图像 1,3 Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 5 中的图像 2,3 Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  7. Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 7 中的图像 1,2 Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 7 中的图像 2,2
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  8. Lenovo Ideapad 320-15ABR Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the battery.
结论
25等其他人完成本指南。
4条评论
hi
can i change the original battery with a more powerful battery?
amin - 回复
Votre explication est très bien détaillée et très explicite. Merci beaucoup vous m'avez vraiment aidé.
Ulrich Foudjin - 回复
I can't get past the first step...pulling out the optical card. The rest I think I can do because I have done things like this before. I unscrewed the screw bu can't pull it out.
Peg Thompson - 回复
Unclip the tiny clips from where you removed the optical card. The back will come off
TopStuff Anime -
添加评论
浏览统计数据:
过去 24 小时: 23
过去 7 天: 202
过去 30 天: 928
总计 74,206
