跳转到主内容
Lenovo Ideapad 320-15ABR Back Panel Replacement
你所需要的
  1. Lenovo Ideapad 320-15ABR Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 2 中的图像 1,3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 2 中的图像 2,3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 2 中的图像 3,3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 3 中的图像 1,2 Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 4 中的图像 1,3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 4 中的图像 2,3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 4 中的图像 3,3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 5 中的图像 1,3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 5 中的图像 2,3 Lenovo Ideapad 320-15ABR Back Panel Replacement: 步骤 5 中的图像 3,3
    • Remove the back panel by pulling it up and away from the laptop.
结论
3等其他人完成本指南。
一条评论
How Is solved Twisted screw and broken inside the frame
For laptop ip520
mohsen JUVE - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 117
总计 13,071
