跳转到主内容
Lenovo Ideapad 310-15IKB Fan Replacement
你所需要的
  1. Lenovo Ideapad 310-15IKB Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Flip the laptop over so the back panel is facing up.
    • Remove the single 6 mm screw from the L-shaped panel using a Phillips #0 screwdriver.
  2. Lenovo Ideapad 310-15IKB Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the panel from the laptop.
  3. Lenovo Ideapad 310-15IKB Fan Replacement: 步骤 3 中的图像 1,1
    • Gently unplug the connector for the fan from the underside by pulling it gently.
  4. Lenovo Ideapad 310-15IKB Fan Replacement: 步骤 4 中的图像 1,1
    • Flip the laptop upright and open it with the screen facing you.
  5. Lenovo Ideapad 310-15IKB Fan Replacement: 步骤 5 中的图像 1,1
    • Use an opening tool to remove the keyboard cover panel, exposing the motherboard and fan.
  6. Lenovo Ideapad 310-15IKB Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the single 3 mm screw holding the fan in place using a Phillips #0 screwdriver.
  7. Lenovo Ideapad 310-15IKB Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the fan by pulling it away from the motherboard and then upwards out of the laptop.
结论
To reassemble your device, follow these instructions in reverse order. Be careful to align the fan screw holes in place.
Sergio Burchell
于02/20/22注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 24
总计 452
