当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Ensure that your device is completely OFF before performing this procedure.
Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
Separate the back lid from the laptop using a plastic opening tool.
Lift the back lid off of the device.
Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
Do not pull on the socket itself or you risk damaging the motherboard.
Remove the two pieces of tape that are holding the battery down.
Remove the five 4 mm Phillips screws securing the battery.
Lift the battery up and out of the device.
Use a Phillips #0 screwdriver to remove four 2.7 mm screws from the touch pad clicker assembly.
Remove the clicker assembly.
Use a plastic opening tool to remove the touch pad.
Time must be taken to work the adhesive without causing damage to the touch pad.
取消:我没有完成这个指南。
与2其他贡献者
于04/06/19注册
181 声望
创作了2篇指南
徽章: 2
IUPUI-WILSON-S19S11G11
2 名成员
创作了6篇指南
i appreciate the tear down. I would like to see the screws that came out of the holes instead of empty screw holes though.
daldal - 2022年10月28日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 1,266
