简介
This guide will allow any owner of a Lenovo Ideapad 110S-11IBR to undergo the process necessary to remove and replace the touchpad of the device to allow for removal. To do so, simply follow the given steps, starting with the removal of the back panel, then the battery, followed by a simply metal plate, and then the touchpad itself. To reassemble, simply follow the steps in reverse order.
Use a Phillips #0 screwdriver to remove four 2.7 mm screws from the touch pad clicker assembly.
即将完成!
结论
