跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will allow any owner of a Lenovo Ideapad 110S-11IBR to undergo the process necessary to remove and replace the touchpad of the device to allow for removal. To do so, simply follow the given steps, starting with the removal of the back panel, then the battery, followed by a simply metal plate, and then the touchpad itself. To reassemble, simply follow the steps in reverse order.
  1. Ensure that your device is completely OFF before performing this procedure.
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Separate the back lid from the laptop using a plastic opening tool. Lift the back lid off of the device.
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool. Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Remove the five 4 mm Phillips screws securing the battery.
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lift the battery up and out of the device. Lift the battery up and out of the device.
    • Lift the battery up and out of the device.
  6. Use a Phillips #0 screwdriver to remove four 2.7 mm screws from the touch pad clicker assembly.
    • Use a Phillips #0 screwdriver to remove four 2.7 mm screws from the touch pad clicker assembly.
  7. Remove the clicker assembly.
    • Remove the clicker assembly.
  8. Use a plastic opening tool to remove the touch pad. Time must be taken to work the adhesive without causing damage to the touch pad.
    • Use a plastic opening tool to remove the touch pad.
    • Time must be taken to work the adhesive without causing damage to the touch pad.
结论
Samaa Aldar
于2019年04月06日注册
181 信誉积分
创作了2篇指南
团队
IUPUI, Team S11-G11, Wilson Spring 2019 IUPUI, Team S11-G11, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S11G11
2 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 17
总计 463
