当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Ensure that your device is completely OFF before performing this procedure.
Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
Separate the back lid from the laptop using a plastic opening tool.
Lift the back lid off of the device.
Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
Do not pull on the socket itself or you risk damaging the motherboard.
Remove the two pieces of tape that are holding the battery down.
Remove the five 4 mm Phillips screws securing the battery.
Lift the battery up and out of the device.
Use your fingers to gently remove the speaker connector from its socket.
Unscrew the four 4mm Phillips screws.
Pull the right speaker carefully under the ribbon cable.
Lift the the left speaker to finish.
取消:我没有完成这个指南。
与1其他贡献者
于09/20/17注册
119 声望
撰写一个指南
徽章: 6
+ 3更多徽章
UNT-THOMAS-F17S6G1
3 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 678
