跳转到主内容
Lenovo Ideapad 110S-11IBR Speaker Replacement
你所需要的
  1. Lenovo Ideapad 110S-11IBR Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 2 中的图像 1,2 Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 2 中的图像 2,2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 3 中的图像 1,2 Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 5 中的图像 1,2 Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 5 中的图像 2,2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Speaker Replacement, Speaker: 步骤 6 中的图像 1,1
    • Use your fingers to gently remove the speaker connector from its socket.
  7. Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 7 中的图像 1,2 Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 7 中的图像 2,2
    • Unscrew the four 4mm Phillips screws.
  8. Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 8 中的图像 1,1
    • Pull the right speaker carefully under the ribbon cable.
  9. Lenovo Ideapad 110S-11IBR Speaker Replacement: 步骤 9 中的图像 1,1
    • Lift the the left speaker to finish.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 668
