跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Lenovo Ideapad 110S-11IBR Battery Replacement
你所需要的
  1. Lenovo Ideapad 110S-11IBR Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Battery Replacement: 步骤 2 中的图像 1,2 Lenovo Ideapad 110S-11IBR Battery Replacement: 步骤 2 中的图像 2,2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Battery Replacement: 步骤 3 中的图像 1,2 Lenovo Ideapad 110S-11IBR Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Battery Replacement: 步骤 5 中的图像 1,2 Lenovo Ideapad 110S-11IBR Battery Replacement: 步骤 5 中的图像 2,2
    • Lift the battery up and out of the device.
结论
8等其他人完成本指南。
一条评论
Great instructions but where can you by a replacement battery? I can’t find one anywhere.
Mark Thompson - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 41
总计 7,900
