跳转到主内容
修复你的物品
维修的权力
商店
简介
This is a quick guide on how to remove and replace the battery.
视频概述
  1. Remove all 11 screws from the base of the laptop.
    • Remove all 11 screws from the base of the laptop.
  2. Once the screws have been removed, lift the base out of the laptop. You may need something pointy to pry it up.
    • Once the screws have been removed, lift the base out of the laptop. You may need something pointy to pry it up.
  3. Next disconnect the battery Next disconnect the battery
    • Next disconnect the battery
  4. Next remove the four screws holding the battery in place.
    • Next remove the four screws holding the battery in place.
  5. And your all done. And your all done.
    • And your all done.
结论
6等其他人完成本指南。
Nick Myers
于2018年04月15日注册
1,061 信誉积分
创作了15篇指南
YOU HAVE TO REMOVE THE KEYBOARD. First, the keyboard is glued with two sided tape so it feels like you are breaking something getting it off. It also has clips all around don't try to undo the bottom until last. Second, there are 3 screws under the keyboard that need to be removed. The third screw was hidden under a Lenovo label, thanks Lenovo. Thirdly, there is no need to disconnect the keyboard harness.
panellockout - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 11
过去的30天: 54
总计 7,812
