跳转到主内容
Lenovo IdeaTab S6000 Vibration Motor Replacement
你所需要的
  1. Lenovo IdeaTab S6000 Vibration Motor Replacement, Battery: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
    • These screens are held in place by glue that is hard to remove. Please take your time to ensure that that this step is done correctly.
  2. Lenovo IdeaTab S6000 Vibration Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the screws from both of the spots that were covered.
  3. Lenovo IdeaTab S6000 Vibration Motor Replacement: 步骤 3 中的图像 1,1
    • DO NOT USE A METAL TOOL FOR THIS.
    • Go all around the casing, prying the screen away from the backing with the spudger.
    • It will make a popping sound each time one of the lock tabs is disconnected.
    • Take your time as you move all around the device when prying the backing off.
  4. Lenovo IdeaTab S6000 Vibration Motor Replacement: 步骤 4 中的图像 1,1
    • Pull off the plastic that is covering the battery cable.
  5. Lenovo IdeaTab S6000 Vibration Motor Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaTab S6000 Vibration Motor Replacement: 步骤 5 中的图像 2,2
    • Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
  6. Lenovo IdeaTab S6000 Vibration Motor Replacement: 步骤 6 中的图像 1,1
    • Remove the battery by grabbing the tab shown and pulling up.
    • The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
  7. Lenovo IdeaTab S6000 Vibration Motor Replacement, Vibration Motor: 步骤 7 中的图像 1,1
    • Use the spudger to pry up the vibration motor.
结论
团队
USF Tampa, Team 10-4, Brown Fall 2014 USF Tampa, Team 10-4, Brown Fall 2014 的会员
USFT-BROWN-F14S10G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 14
总计 985
