跳转到主内容
Lenovo IdeaTab S2109A-F System Board Replacement
你所需要的
  1. Lenovo IdeaTab S2109A-F System Board Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo IdeaTab S2109A-F System Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F System Board Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaTab S2109A-F System Board Replacement: 步骤 2 中的图像 2,2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F System Board Replacement: 步骤 3 中的图像 1,1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F System Board Replacement, Unscrewing the System Board: 步骤 4 中的图像 1,2 Lenovo IdeaTab S2109A-F System Board Replacement, Unscrewing the System Board: 步骤 4 中的图像 2,2
    • Locate the long, L-shaped system board; copper foil runs most of its length.
    • Remove the 10 2mm PH00 black screws located on the edges of the system board using a PH00 Screwdriver.
  5. Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the First Connection to the System Board: 步骤 5 中的图像 1,1
    • First Disconnect the gold connector by lifting the latch on it up and pulling it loose using the latch to pull.
  6. Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the next three connections of the System Board: 步骤 6 中的图像 1,2 Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the next three connections of the System Board: 步骤 6 中的图像 2,2
    • As you lift the board up you will notice two more connections, one near the power switch and one on the I/O Panel.
    • Remove each one with a minimal amount of upward pulling force as you flip the board over.
  7. Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the final connector of the System Board.: 步骤 7 中的图像 1,3 Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the final connector of the System Board.: 步骤 7 中的图像 2,3 Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the final connector of the System Board.: 步骤 7 中的图像 3,3
    • To disconnect the system board there is one last connection.
    • Lift up the back latch on this connection and the orange ribbon should slide right out without any effort thus disconnecting the board.
结论
Timothy
于01/30/15注册
301 声望
创作了3篇指南
团队
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015 的会员
USFT-WATKINS-W15S17G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 501
