跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaTab S2109A-F Speaker Replacement
你所需要的
    1. Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: 步骤 1 中的图像 2,2
      • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
      • Place the tablet on its screen and use the opening tool to remove the back cover.
      • With the tool, place slight pressure on the tablet to pry the back panel off.
      添加评论
    2. Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 2 中的图像 2,2
      • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
      • Pull the battery gently until the cord has no slack.
      询问修复机器人
      添加评论
    3. Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 3 中的图像 1,1
      • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
      • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
      • Remove the battery from the device.
      询问修复机器人
      添加评论
    1. Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
      • Remove the ten 2 mm black screws from the edges of the system board with a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 5 中的图像 1,1
      • Disconnect the gold connector by lifting the latch with the plastic opening tool.
      询问修复机器人
      添加评论
    3. Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 6 中的图像 2,2
      • Pull up on the L-shaped board.
      • The bottom and top connection points should disconnect.
      询问修复机器人
      添加评论
    4. Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 7 中的图像 2,2
      • Remove the seven 2 mm black screws connecting the speakers using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    5. Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 8 中的图像 1,3 Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 8 中的图像 2,3 Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 8 中的图像 3,3
      • Lift the disconnected speakers from their resting position.
      • Grab the red and black cable with your index finger and thumb.
      询问修复机器人
      添加评论
    6. Lenovo IdeaTab S2109A-F Speaker Replacement: 步骤 9 中的图像 1,1
      • Pull up on the connection to disconnect the speakers.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Caelen
于01/16/15注册
228 声望
创作了2篇指南
团队
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015 的会员
USFT-WATKINS-W15S17G3
4 名成员
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 25
过去 30 天: 59
总计 838
