跳转到主内容
Lenovo IdeaTab S2109A-F Camera Replacement
你所需要的
  1. Lenovo IdeaTab S2109A-F Camera Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo IdeaTab S2109A-F Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Camera Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaTab S2109A-F Camera Replacement: 步骤 2 中的图像 2,2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Camera Replacement: 步骤 3 中的图像 1,1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: 步骤 4 中的图像 1,3 Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: 步骤 4 中的图像 2,3 Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: 步骤 4 中的图像 3,3
    • Remove the two 4 mm screws from the right side of the housing with the Phillips #00 screwdriver.
  5. Lenovo IdeaTab S2109A-F Camera Replacement, Unscrewing the system board: 步骤 5 中的图像 1,2 Lenovo IdeaTab S2109A-F Camera Replacement, Unscrewing the system board: 步骤 5 中的图像 2,2
    • Locate the long, L-shaped system board.
    • Copper runs most of this length.
    • Remove the ten 2 mm screws securing the system board with a Phillips #00 screwdriver.
  6. Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the system board: 步骤 6 中的图像 1,1
    • Flip the central latch with a large opening tool to expose a gold connector.
    • Gently pull the gold connector using the latch.
  7. Lenovo IdeaTab S2109A-F Camera Replacement, Moving the System board: 步骤 7 中的图像 1,2 Lenovo IdeaTab S2109A-F Camera Replacement, Moving the System board: 步骤 7 中的图像 2,2
    • Pull up the L-shaped board to disconnect the two connectors at the top and bottom of the board.
  8. Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the camera: 步骤 8 中的图像 1,2 Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the camera: 步骤 8 中的图像 2,2
    • Grab the camera connection with your index finger thumb.
    • Disconnect the camera by gently pulling on this wire.
结论
To reassemble this device, follow these instructions in reverse order.
Timothy
于01/30/15注册
301 声望
创作了3篇指南
团队
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015 的会员
USFT-WATKINS-W15S17G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 344
