跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Lenovo IdeaTab S2107A-F Android 7",请使用我们的维修手册
  1. Lenovo IdeaTab S2107A-F Teardown, Front and Back Before Opening It Up: 步骤 1 中的图像 1,2 Lenovo IdeaTab S2107A-F Teardown, Front and Back Before Opening It Up: 步骤 1 中的图像 2,2
    • Ready to start tearing it apart. It was a cheap tablet several years ago, it's wifi is really slow, so it's not useable these days. Let's see what's inside.
  2. Lenovo IdeaTab S2107A-F Teardown, Remove the Rear Top Cover: 步骤 2 中的图像 1,2 Lenovo IdeaTab S2107A-F Teardown, Remove the Rear Top Cover: 步骤 2 中的图像 2,2
    • We're looking at the rear top here. It just slides toward the top of the tablet and lifts off, exposing the camera and micro SD card holder.
  3. Lenovo IdeaTab S2107A-F Teardown, Remove 3 Small Phillips Screws, and One Tiny Phillips Screw: 步骤 3 中的图像 1,3 Lenovo IdeaTab S2107A-F Teardown, Remove 3 Small Phillips Screws, and One Tiny Phillips Screw: 步骤 3 中的图像 2,3 Lenovo IdeaTab S2107A-F Teardown, Remove 3 Small Phillips Screws, and One Tiny Phillips Screw: 步骤 3 中的图像 3,3
    • A number 0 phillips screw driver works for all of these screws, and all steps going forward.
  4. Lenovo IdeaTab S2107A-F Teardown, A Picture of the Holes of the Small and Tiny Empty Screws: 步骤 4 中的图像 1,1
    • Insert wisdom here.
  5. Lenovo IdeaTab S2107A-F Teardown, Find the Hidden Phillips Screw, and Remove It: 步骤 5 中的图像 1,3 Lenovo IdeaTab S2107A-F Teardown, Find the Hidden Phillips Screw, and Remove It: 步骤 5 中的图像 2,3 Lenovo IdeaTab S2107A-F Teardown, Find the Hidden Phillips Screw, and Remove It: 步骤 5 中的图像 3,3
    • The rear cover wouldn't pull off, even when prying with my "spudger". I didn't want to break the tablet (yet). Then I noticed the round white spot. I scraped away the brittle white paint, exposing another phillips screw, and removed it. (There goes my warranty! They made it tamper evident.)
  6. Lenovo IdeaTab S2107A-F Teardown, Small and Tiny Screws Removed: 步骤 6 中的图像 1,1
    • Total 5 so far, 1 tiny, 4 small
  7. Lenovo IdeaTab S2107A-F Teardown, Slide the Main Rear Cover Off: 步骤 7 中的图像 1,2 Lenovo IdeaTab S2107A-F Teardown, Slide the Main Rear Cover Off: 步骤 7 中的图像 2,2
    • With the hidden screw removed, the rear cover easily slides off. Push it towards the bottom of the tablet with your thumbs. It moves 1/4 inch and stops, shown in the second picture. Then it is freely lifted off the back.
    • Sorry for the blurry pictures. My photos get sharper as we go along. Really
  8. Lenovo IdeaTab S2107A-F Teardown, Battery and Speakers Are Exposed: 步骤 8 中的图像 1,1
    • Stero speakers are at the tablet's bottom. The 3.7 VDC Lithium Polymer battery is right there. 13.7 Wh / 3700 mAh. Fairly large for a cheap tablet. It adds to the heft of this tablet.
  9. Lenovo IdeaTab S2107A-F Teardown, Battery is Glued In.  And Appears Hard-Wired In.: 步骤 9 中的图像 1,1
    • I pried the battery up slowly, it's sticky rubber type glue, but it was a warm day, so it came loose with some patience. (I don't have a proper spudger, a plastic picnic knife had to do instead.)
  10. Lenovo IdeaTab S2107A-F Teardown, Lots More Phillips Screws to Remove: 步骤 10 中的图像 1,1
    • With the main back cover off, there are lots of phillips screws scattered around the case, surrounding the battery. I counted 10 more screws.
    • 1 at the tablet's top above the battery, 3 across (2 small and 1 tiny), 2 across at the midpoint of the battery, 2 across, and 2 across below the battery at the tablet's bottom.
  11. Lenovo IdeaTab S2107A-F Teardown, I Tried Prying the Inside Case Apart: 步骤 11 中的图像 1,3 Lenovo IdeaTab S2107A-F Teardown, I Tried Prying the Inside Case Apart: 步骤 11 中的图像 2,3 Lenovo IdeaTab S2107A-F Teardown, I Tried Prying the Inside Case Apart: 步骤 11 中的图像 3,3
    • With all those screws out, I tried prying it apart to expose the motherboard, but it would come all the way off. There's something still holding it together . . .
  12. Lenovo IdeaTab S2107A-F Teardown, Another Hidden Screw: 步骤 12 中的图像 1,3 Lenovo IdeaTab S2107A-F Teardown, Another Hidden Screw: 步骤 12 中的图像 2,3 Lenovo IdeaTab S2107A-F Teardown, Another Hidden Screw: 步骤 12 中的图像 3,3
    • Something was holding it together at the tablet's top. So, I pealed away the innocent looking serial number sticker, and there it was. One more phillips screw. With that gone, the plastic inside cover lifted off easily. It's apart, and there's the motherboard.
  13. Lenovo IdeaTab S2107A-F Teardown, Removing the Battery Wires: 步骤 13 中的图像 1,2 Lenovo IdeaTab S2107A-F Teardown, Removing the Battery Wires: 步骤 13 中的图像 2,2
    • The battery has 5 wires, 2 red hot wire, 2 black ground, and 1 white. I assume the white is used by the cpu to monitor charging? battery temperature?
    • I measured 3.9 VDC red-black on battery power, and 4.1 VDC when the battery was charging through its USB port.
    • And 3.9 VDC red-white on battery power, 2.7 VDC when charging. While white-black was 0.0 VDC on battery, and 1.3 VDC when charging.
  14. Lenovo IdeaTab S2107A-F Teardown, Battery Wires Pried Up Easily: 步骤 14 中的图像 1,2 Lenovo IdeaTab S2107A-F Teardown, Battery Wires Pried Up Easily: 步骤 14 中的图像 2,2
    • With the glue loose, and the wires removed, the battery is available as a spare for me.
  15. Lenovo IdeaTab S2107A-F Teardown, Small Devices: 步骤 15 中的图像 1,3 Lenovo IdeaTab S2107A-F Teardown, Small Devices: 步骤 15 中的图像 2,3 Lenovo IdeaTab S2107A-F Teardown, Small Devices: 步骤 15 中的图像 3,3
    • The rear camera has a short cable that pries off easily.
    • The haptic motor sits on the side of the tablet. I used it with the on-screen keyboard to help me when typing on the tablet
    • The microphone is on the other side of the tablet, also easily removeable.
  16. Lenovo IdeaTab S2107A-F Teardown, Remove Motherboard: 步骤 16 中的图像 1,2 Lenovo IdeaTab S2107A-F Teardown, Remove Motherboard: 步骤 16 中的图像 2,2
    • There's one phillips screw in the middle of the motherboard, near to where the battery was. Remove that and then the circuit board pries apart. It's a tight fit, but with the screw removed it's just a friction fit.
    • And there it is flopped over on it's back, still attached by ribbon cables.
  17. Lenovo IdeaTab S2107A-F Teardown, Motherboard and CPU: 步骤 17 中的图像 1,2 Lenovo IdeaTab S2107A-F Teardown, Motherboard and CPU: 步骤 17 中的图像 2,2
    • Mediatek CPU
  18. Lenovo IdeaTab S2107A-F Teardown, Pry Loose the Ribbon Cables: 步骤 18 中的图像 1,3 Lenovo IdeaTab S2107A-F Teardown, Pry Loose the Ribbon Cables: 步骤 18 中的图像 2,3 Lenovo IdeaTab S2107A-F Teardown, Pry Loose the Ribbon Cables: 步骤 18 中的图像 3,3
    • Video and Touch Screen cables, I assume.
  19. Lenovo IdeaTab S2107A-F Teardown, Remove the Screen?  Not Without Breakage: 步骤 19 中的图像 1,1
    • The tablet's screen is tightly held in the plastic case. I tried prying it apart, but didn't want to crack it. You can see the metal backing, this screen is heavy with all that metal. I stopped here so that I wouldn't break the glass on the front.
    • I really wanted to see if the screen was usable in a future project. But the ribbon cable connections looked proprietary, so I'm not hopeful.
Allen
于01/02/18注册
1,449 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 631
