跳转到主内容
Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement
你所需要的
  1. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, Battery: 步骤 1 中的图像 1,1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 2 中的图像 2,2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 4 中的图像 2,2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 5 中的图像 2,2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  6. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, System Board: 步骤 6 中的图像 1,3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, System Board: 步骤 6 中的图像 2,3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, System Board: 步骤 6 中的图像 3,3
    • Remove three silver 1.8 mm Phillips #00 screws.
  7. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 7 中的图像 1,3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 7 中的图像 2,3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 8 中的图像 2,2
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 9 中的图像 1,2 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 9 中的图像 2,2
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 10 中的图像 1,3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 10 中的图像 2,3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 10 中的图像 3,3
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
  11. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, WIFI/GPS Antenna: 步骤 11 中的图像 1,1
    • Once the system board has been removed, you can access the WIFI/GPS antenna.
  12. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 12 中的图像 1,3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 12 中的图像 2,3 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: 步骤 12 中的图像 3,3
    • Insert the blue prying tool at the corner of the antenna. Pry up slowly, and move it across the antenna.
    • There is an adhesive holding the antenna in place, so it may take a little bit of force and movement to take off the antenna.
    • The antenna falls out easily once fully pried out.
结论
2等其他人完成本指南。
Bcohen
于04/14/14注册
436 声望
创作了2篇指南
团队
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G19
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 31
总计 3,353
