跳转到主内容
Lenovo IdeaTab A2109 IO Board Replacement
你所需要的
  1. Lenovo IdeaTab A2109 IO Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 IO Board Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaTab A2109 IO Board Replacement: 步骤 2 中的图像 2,2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 IO Board Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaTab A2109 IO Board Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 IO Board Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaTab A2109 IO Board Replacement: 步骤 4 中的图像 2,2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 IO Board Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaTab A2109 IO Board Replacement: 步骤 5 中的图像 2,2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  6. Lenovo IdeaTab A2109 IO Board Replacement, System Board: 步骤 6 中的图像 1,3 Lenovo IdeaTab A2109 IO Board Replacement, System Board: 步骤 6 中的图像 2,3 Lenovo IdeaTab A2109 IO Board Replacement, System Board: 步骤 6 中的图像 3,3
    • Remove three silver 1.8 mm Phillips #00 screws.
  7. Lenovo IdeaTab A2109 IO Board Replacement: 步骤 7 中的图像 1,3 Lenovo IdeaTab A2109 IO Board Replacement: 步骤 7 中的图像 2,3 Lenovo IdeaTab A2109 IO Board Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Lenovo IdeaTab A2109 IO Board Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaTab A2109 IO Board Replacement: 步骤 8 中的图像 2,2
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Lenovo IdeaTab A2109 IO Board Replacement: 步骤 9 中的图像 1,2 Lenovo IdeaTab A2109 IO Board Replacement: 步骤 9 中的图像 2,2
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Lenovo IdeaTab A2109 IO Board Replacement: 步骤 10 中的图像 1,3 Lenovo IdeaTab A2109 IO Board Replacement: 步骤 10 中的图像 2,3 Lenovo IdeaTab A2109 IO Board Replacement: 步骤 10 中的图像 3,3
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
  11. Lenovo IdeaTab A2109 IO Board Replacement, IO Board: 步骤 11 中的图像 1,2 Lenovo IdeaTab A2109 IO Board Replacement, IO Board: 步骤 11 中的图像 2,2
    • Remove the following two screws:
    • M 5.3 x 1.75 mm #00 phillips screws (silver)
  12. Lenovo IdeaTab A2109 IO Board Replacement: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Once the screws are out, use the tweezers to pull the board straight out.
结论
9等其他人完成本指南。
Brian
于04/22/14注册
565 声望
创作了2篇指南
团队
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G19
4 名成员
创作了15篇指南
6条评论
Great guide but make sure you REMOVE THE AUX SD CARD FIRST if installed or you will break the card and or card slot.
Other than that, no problems. I got the io board for $26 and I put it in for free.
James Bush - 回复
I need an io board for cheap... I might have to make a guide on how to attempt to repair io card without proper tools and a filed down soldering iron tip
Ember Leona - 回复
Thank you this was helpful. I think I fixed my screen flickers the LCD ribbon is under the battery and the ribbon from the volume board on the right I think that's related to the screen rotation lock. Those needed to be flipped up and reseated. Thanks
Ember Leona - 回复
Thanks Very much
the guide is very clear
i have done the job successfully
omimh - 回复
Excelente guía. Muchas gracias.
Larry Pacheco - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 4,924
