跳转到主内容
Lenovo IdeaTab A2109 Battery Replacement
你所需要的
  1. Lenovo IdeaTab A2109 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Battery Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaTab A2109 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 Battery Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaTab A2109 Battery Replacement: 步骤 3 中的图像 2,2
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 Battery Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaTab A2109 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 Battery Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaTab A2109 Battery Replacement: 步骤 5 中的图像 2,2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
结论
9等其他人完成本指南。
Kyle
于04/22/14注册
581 声望
创作了2篇指南
团队
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G19
4 名成员
创作了15篇指南
一条评论
If there is an SD Micro memory card installed, REMOVE IT!, before the back cover. Otherwise, the card reader/writer will be damaged.
FilAm Harley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 8,265
