跳转到主内容
Lenovo IdeaTab A1000L Battery Replacement
你所需要的
  1. Lenovo IdeaTab A1000L Battery Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo IdeaTab A1000L Battery Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo IdeaTab A1000L Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Be sure to power off your device before taking it apart.
    • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
    • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
  2. Lenovo IdeaTab A1000L Battery Replacement: 步骤 2 中的图像 1,3 Lenovo IdeaTab A1000L Battery Replacement: 步骤 2 中的图像 2,3 Lenovo IdeaTab A1000L Battery Replacement: 步骤 2 中的图像 3,3
    • Locate the black back plate, above the battery.
    • Using a Phillips #000 screwdriver remove the 7 silver 3.5mm screws from the back plate.
    • Next, with the same screwdriver, remove the black 4.1mm screw.
    • Gently remove the back plate from the device.
  3. Lenovo IdeaTab A1000L Battery Replacement: 步骤 3 中的图像 1,3 Lenovo IdeaTab A1000L Battery Replacement: 步骤 3 中的图像 2,3 Lenovo IdeaTab A1000L Battery Replacement: 步骤 3 中的图像 3,3
    • Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and pry it up.
    • Again, use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
    • Gently place the battery aside.
结论
10等其他人完成本指南。
Peter Newell
于04/15/14注册
627 声望
创作了2篇指南
团队
Cal Poly, Team 7-21, Regan Spring 2014 Cal Poly, Team 7-21, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G21
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 17
总计 22,982
