跳转到主内容
Lenovo IdeaPad y510p Network Card Replacement
你所需要的
  1. Lenovo IdeaPad y510p Network Card Replacement, Network Card: 步骤 1 中的图像 1,2 Lenovo IdeaPad y510p Network Card Replacement, Network Card: 步骤 1 中的图像 2,2
    • Slide the left battery lock to the left
    • While holding the right battery lock to the right, pull the battery out.
  2. Lenovo IdeaPad y510p Network Card Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad y510p Network Card Replacement: 步骤 2 中的图像 2,2
    • Slide the disk drive lock up.
    • While holding the lock in the middle of the laptop up, remove the disk drive
  3. Lenovo IdeaPad y510p Network Card Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad y510p Network Card Replacement: 步骤 3 中的图像 2,2
    • Unscrew all nine of the backplate screws with a #0 Phillips screwdriver.
  4. Lenovo IdeaPad y510p Network Card Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad y510p Network Card Replacement: 步骤 4 中的图像 2,2
    • Carefully pry the backplate off of the laptop.
  5. Lenovo IdeaPad y510p Network Card Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad y510p Network Card Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad y510p Network Card Replacement: 步骤 5 中的图像 3,3
    • Pry the wireless antenna connectors off of the network card.
    • Be careful not to damage the connectors on the wireless card.
  6. Lenovo IdeaPad y510p Network Card Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad y510p Network Card Replacement: 步骤 6 中的图像 2,2
    • Unscrew the screw holding the network card in place with a #0 Phillips screwdriver
  7. Lenovo IdeaPad y510p Network Card Replacement: 步骤 7 中的图像 1,1
    • Slide the network card out of the connector.
结论
3等其他人完成本指南。
Alex David
于10/02/17注册
173 声望
撰写一个指南
团队
Michigan Tech, Team S3-G4, Galliah Fall 2017 Michigan Tech, Team S3-G4, Galliah Fall 2017 的会员
MTU-GALLIAH-F17S3G4
2 名成员
创作了1篇指南
一条评论
Steps to White list the Newly installed network card in the BIOS. Follow Steps : http://www.thecosmosphere.com/how-to-rem...
I used the Intel Centrino Advanced-N 6235 6235ANHMW Wlan Bluetooth 4.0 Half MINI Card 802.11 a/b/g/n Dual-band 300 Mbps as replacement.
Amazon : https://www.amazon.com/gp/product/B009SJ...
John Santhosh - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 2,535
