跳转到主内容
Lenovo IdeaPad Z570 Screen Replacement
你所需要的
  1. Lenovo IdeaPad Z570 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Screen Replacement: 步骤 2 中的图像 1,1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Screen Replacement: 步骤 3 中的图像 1,1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Screen Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad Z570 Screen Replacement: 步骤 4 中的图像 2,2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Open up the laptop with the screen facing you.
  6. Lenovo IdeaPad Z570 Screen Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad Z570 Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the two rubber square screw covers located in the left and right lower hand corners of the screen.
  7. Lenovo IdeaPad Z570 Screen Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaPad Z570 Screen Replacement: 步骤 7 中的图像 2,2
    • Unscrew the two 4 mm screws behind the two rubber screw covers using the Phillips #0 screwdriver.
  8. Lenovo IdeaPad Z570 Screen Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaPad Z570 Screen Replacement: 步骤 8 中的图像 2,2
    • Using the opening tool, pry open the plastic screen border, beginning with the upper right hand corner then working your way around.
    • Pry off the screen cover from the device.
  9. Lenovo IdeaPad Z570 Screen Replacement: 步骤 9 中的图像 1,2 Lenovo IdeaPad Z570 Screen Replacement: 步骤 9 中的图像 2,2
    • Remove the two 2 mm screws at the top two corners of the screen using the Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Screen Replacement: 步骤 10 中的图像 1,2 Lenovo IdeaPad Z570 Screen Replacement: 步骤 10 中的图像 2,2
    • Loosen the four 2 mm screws located at the bottom corners of the screen.
    • These screws cannot be removed.
  11. Lenovo IdeaPad Z570 Screen Replacement: 步骤 11 中的图像 1,3 Lenovo IdeaPad Z570 Screen Replacement: 步骤 11 中的图像 2,3 Lenovo IdeaPad Z570 Screen Replacement: 步骤 11 中的图像 3,3
    • Tilt the screen forward gently.
    • Remove four 3 mm screws on the sides of the brackets holding the screen (two on the left side and two on the right side) using the Phillips #0 screwdriver.
  12. Lenovo IdeaPad Z570 Screen Replacement: 步骤 12 中的图像 1,1
    • Lean the LCD screen face-down on the keyboard gently.
  13. Lenovo IdeaPad Z570 Screen Replacement: 步骤 13 中的图像 1,3 Lenovo IdeaPad Z570 Screen Replacement: 步骤 13 中的图像 2,3 Lenovo IdeaPad Z570 Screen Replacement: 步骤 13 中的图像 3,3
    • Gently remove the adhesive covering surrounding the wires that’s connected to the back of the screen.
    • Disconnect the plug from the connection terminal.
    • Remove the screen completely.
结论
另外一个人完成了本指南。
Daniel Lopes
于03/08/19注册
610 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,077
