简介
In order to proceed with this guide, you should know that the laptop must not be plugged in for safety reasons. The laptop should also be powered off and the battery drained. Once completed, safely dispose of the old charging port.
你所需要的
Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
Place the laptop on the backside with the battery facing away from you.
Remove the eleven 7 mm screws located around the edge of the backside of the laptop using the Phillips #0 screwdriver.
即将完成!
结论
