跳转到主内容
Lenovo IdeaPad Yoga 11S Trackpad Replacement
你所需要的
  1. Lenovo IdeaPad Yoga 11S Trackpad Replacement, Top Assembly: 步骤 1 中的图像 1,3 Lenovo IdeaPad Yoga 11S Trackpad Replacement, Top Assembly: 步骤 1 中的图像 2,3 Lenovo IdeaPad Yoga 11S Trackpad Replacement, Top Assembly: 步骤 1 中的图像 3,3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Trackpad Replacement, Remove Keyboard: 步骤 2 中的图像 1,1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Trackpad Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Trackpad Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad Yoga 11S Trackpad Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad Yoga 11S Trackpad Replacement: 步骤 4 中的图像 3,3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
  5. Lenovo IdeaPad Yoga 11S Trackpad Replacement, Trackpad: 步骤 5 中的图像 1,2 Lenovo IdeaPad Yoga 11S Trackpad Replacement, Trackpad: 步骤 5 中的图像 2,2
    • Position the removed top encasing where it sits on the keyboard and trackpad. The inside of the top encasing should be upward facing.
    • Use a plastic opening tool to lift the retaining flap to disconnect the ZIF connector.
    • Gently pull the trackpad cable out of the socket.
  6. Lenovo IdeaPad Yoga 11S Trackpad Replacement: 步骤 6 中的图像 1,1
    • Locate the four 1.6mm screws that connect the trackpad to the top housing.
    • Use a Phillips #00 Screwdriver to remove the screws.
  7. Lenovo IdeaPad Yoga 11S Trackpad Replacement: 步骤 7 中的图像 1,1
    • Flip the top assembly over so the keyboard is on top.
    • Gently push the trackpad out of its position.
结论
另外一个人完成了本指南。
Landon Epps
于03/26/15注册
982 声望
创作了5篇指南
团队
Baylor, Team 7-11, Williams Spring 2015 Baylor, Team 7-11, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G11
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 4,098
