跳转到主内容
Lenovo IdeaPad Yoga 11S Top Assembly Replacement
你所需要的
  1. Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: 步骤 1 中的图像 1,3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: 步骤 1 中的图像 2,3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: 步骤 1 中的图像 3,3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
    under the rubber pads can be, or are? the bottom pads are much more secured.
    zZz - 回复
    2 of them. The 2 near the screen hinges. They release the keyboard.
    jsoper - 回复
    Mine had t5 Torx screws on the perimeter and center, with #0 phillips underneath the foot pads.
    dan lench - 回复
    Mine also had the T5 Torx screws.
    Willem -
  2. Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Remove Keyboard: 步骤 2 中的图像 1,1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Top Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Top Assembly Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement: 步骤 4 中的图像 3,3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
    You need to remove the keyboard too otherwise you will miss the 2 screws underneath!
    jonesadam08 - 回复
    this is a terrible guide, you unlatch the ribbons in the prior step with screws.
    zZz - 回复
    I’m pretty sure all you need to do is remove 4 screws on the back (2 under the foot pads on the upper side and 2 in the middle, all beneath the keyboard), then loosen the keyboard from the top slide forward and up, not the whole cover, then the dimm slot is right there
    Jeff Ferguson - 回复
结论
2等其他人完成本指南。
Landon Epps
于03/26/15注册
982 声望
创作了5篇指南
团队
Baylor, Team 7-11, Williams Spring 2015 Baylor, Team 7-11, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G11
3 名成员
创作了10篇指南
一条评论
I am looking into buying one of these but looking at your pictures I can't find the SSD. Is it user upgradeable?
ggr - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 3,115
