跳转到主内容
Lenovo IdeaPad Yoga 11S RAM Replacement
你所需要的
  1. Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: 步骤 1 中的图像 1,3 Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: 步骤 1 中的图像 2,3 Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: 步骤 1 中的图像 3,3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S RAM Replacement, Remove Keyboard: 步骤 2 中的图像 1,1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S RAM Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S RAM Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad Yoga 11S RAM Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad Yoga 11S RAM Replacement: 步骤 4 中的图像 3,3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
  5. Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: 步骤 5 中的图像 1,3 Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: 步骤 5 中的图像 2,3 Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: 步骤 5 中的图像 3,3
    • Locate the RAM module.
    • Locate the tabs on both sides of the RAM module
    • Spread both tabs outward at the same time in order to release the RAM module.
  6. Lenovo IdeaPad Yoga 11S RAM Replacement: 步骤 6 中的图像 1,1
    • Grab the RAM module and carefully pull it out from its position.
结论
6等其他人完成本指南。
Landon Epps
于03/26/15注册
982 声望
创作了5篇指南
团队
Baylor, Team 7-11, Williams Spring 2015 Baylor, Team 7-11, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G11
3 名成员
创作了10篇指南
2条评论
Excelente… easy and simply.
Iver Antelo - 回复
At Step 3. Replace the memory now that it is exposed. You don't have to do steps 4-5, I don't think you have to remove the 10 small screws either.
Just the Philips under the foot tabs and carefully remove the keyboard, pull the tabs back that secure the memory and replace with new memory.
Kyle Brock - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 36
总计 9,112
