跳转到主内容
Lenovo IdeaPad Yoga 11S Display Replacement
你所需要的
  1. Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: 步骤 1 中的图像 1,3 Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: 步骤 1 中的图像 2,3 Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: 步骤 1 中的图像 3,3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Display Replacement, Remove Keyboard: 步骤 2 中的图像 1,1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Display Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Display Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad Yoga 11S Display Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad Yoga 11S Display Replacement: 步骤 4 中的图像 3,3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
  5. Lenovo IdeaPad Yoga 11S Display Replacement, Display: 步骤 5 中的图像 1,1
    • Keep the device positioned where it sits on the bottom encasing with the display open.
    • Locate the four 1.9mm screws used to attach the display brackets to the bottom enclosure of the device.
    • Use a Phillips #00 Screwdriver to remove the four screws.
  6. Lenovo IdeaPad Yoga 11S Display Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to lift the retaining flap to disconnect the right display cable connector.
    • Gently pull the display cable out of the socket.
  7. Lenovo IdeaPad Yoga 11S Display Replacement: 步骤 7 中的图像 1,1
    • Use a plastic opening tool to lift the retaining flap to disconnect the left display cable connector.
  8. Lenovo IdeaPad Yoga 11S Display Replacement: 步骤 8 中的图像 1,1
    • Gently lift the display to detach it from the device.
结论
5等其他人完成本指南。
Landon Epps
于03/26/15注册
982 声望
创作了5篇指南
团队
Baylor, Team 7-11, Williams Spring 2015 Baylor, Team 7-11, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G11
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 4,774
