跳转到主内容
Lenovo IdeaPad Y700-15ACZ Motherboard Replacement
你所需要的
  1. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Lenovo IdeaPad Y700-15ACZ Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Flip the laptop upside down so that the bottom is facing up.
    • Using the #0 Phillips screwdriver, unscrew the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws) that attach the cover to the laptop.
  2. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: 步骤 2 中的图像 1,1
    • After removing the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws), use the Jimmy to pop up the cover and remove it from the laptop.
  3. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: 步骤 3 中的图像 1,3 Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: 步骤 3 中的图像 2,3 Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: 步骤 3 中的图像 3,3
    • Unscrew the 16 Phillips #0 screws and 1 Philips #00 screw ( 0.5 mm screws, one 1 mm screw) from the motherboard, the fan, and the speaker to remove and replace the motherboard.
结论
Kevin
于09/28/22注册
351 声望
创作了3篇指南
团队
CSU Los Angeles, Team 6-6, Adachi Fall 2022 CSU Los Angeles, Team 6-6, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S6G6
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 278
