跳转到主内容
Lenovo IdeaPad Y580-2099 Speaker Replacement
你所需要的
  1. Lenovo IdeaPad Y580-2099 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Speaker Replacement, Keyboard: 步骤 3 中的图像 1,2 Lenovo IdeaPad Y580-2099 Speaker Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 4 中的图像 1,1
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 5 中的图像 2,2
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: 步骤 6 中的图像 1,3 Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: 步骤 6 中的图像 2,3 Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Flip laptop back over and unscrew the disc drive screw.
    • Remove the disc drive.
    • Unscrew all of the screws on the back of the device.
  7. Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 7 中的图像 1,3 Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 7 中的图像 2,3 Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 7 中的图像 3,3
    • Flip the device over.
    • Unplug the two wires, as shown in the images.
    • Lift up on the keyboard bezel.
    • The bezel should come up easy, if not go back and make sure all screws have been removed.
  8. Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 8 中的图像 2,2
    • Unscrew the screws on the motherboard.
    • Disconnect the three connectors the two black and one white.
  9. Lenovo IdeaPad Y580-2099 Speaker Replacement: 步骤 9 中的图像 1,1
    • Carefully lift up the motherboard.
    • Unplug the wires underneath the motherboard.
    • Be careful not to rip the wires underneath the motherboard while lifting it up.
  10. Lenovo IdeaPad Y580-2099 Speaker Replacement, Speakers: 步骤 10 中的图像 1,2 Lenovo IdeaPad Y580-2099 Speaker Replacement, Speakers: 步骤 10 中的图像 2,2
    • Unscrew the two screws in each of the corners of the speakers.
    • Remove the speakers.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,444
