跳转到主内容
Lenovo IdeaPad Y500 Keyboard Replacement
你所需要的
  1. Lenovo IdeaPad Y500 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
  2. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Unlike the first lock, this lock is spring loaded and must be held in place when used.
    • Slide the lock to the left (in the direction of the arrow below the lock) and hold in place.
  3. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Gently pull battery away from the computer while holding open the lock.
  4. Lenovo IdeaPad Y500 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement, Keyboard: 步骤 4 中的图像 3,3
    • Unlock the battery latch by pulling it up.
    • It should reveal red underneath when it's unlocked.
  5. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Push the latch down and then hold in position.
    • Pull the optical drive out.
  6. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 6 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 6 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Remove nine screws with a Phillips #1 screwdriver.
  7. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 7 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 7 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 7 中的图像 3,3
    • Pull up on the loosened cover to remove.
    • Remove two screws with a Phillips #1 screwdriver.
  8. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 8 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 8 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 8 中的图像 3,3
    • Pull the tab straight to the left until part releases.
    • Lift up the part to remove completely.
  9. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 9 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 9 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 9 中的图像 3,3
    • To release the DIMM, pull the tabs on either side away from each other simultaneously.
    • The DIMM will pop out on its own.
  10. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 10 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 10 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 10 中的图像 3,3
    • To disconnect the Wi-Fi cables, use a spudger to gently push up under them.
    • Wi-Fi cables are delicate.
  11. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 11 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 11 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 11 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove the two screws.
    • Once screws are out, the card will just pop out.
  12. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 12 中的图像 1,1
    • Remove three screws using a Phillips #1 screwdriver.
  13. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 13 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 13 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 13 中的图像 3,3
    • With the laptop upside down, open slightly.
    • To remove the keyboard, push the back of the keyboard forward with your thumb while pulling away from the laptop on the other side.
    • You will not be able to pull the keyboard completely away. The cables are still connected to the laptop.
  14. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 14 中的图像 1,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 14 中的图像 2,3 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 14 中的图像 3,3
    • To release the cables, use the spudger to push both ends on the side of the cable.
    • Gently pull the cables up to disconnect.
  15. Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 15 中的图像 1,2 Lenovo IdeaPad Y500 Keyboard Replacement: 步骤 15 中的图像 2,2
    • Pull the keyboard up and away from the laptop to remove it.
结论
3等其他人完成本指南。
团队
UW Tacoma, Team S1-G2, Cardinal Spring 2019 UW Tacoma, Team S1-G2, Cardinal Spring 2019 的会员
UWT-CARDINAL-S19S1G2
4 名成员
创作了5篇指南
一条评论
Not sure if removing all components was really necessary just to replace the keyboard but I still did it and succeeded in replacing the keyboard. Thank you for great and detailed instructions.
Grzegorz Krugły - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 1,970
