当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn off your laptop before starting.
Flip the laptop over so the model stickers are facing up.
Slide the left battery lock to the unlock position and release.
Slide the right battery lock to the unlock positon and hold it in place.
While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
Using the Phillips #0 screwdriver remove the eight 8mm screws that fasten the bottom cover.
Lift the bottom cover off using a metal spudger and set it aside.
Simultaneously pull apart both clips that are holding the RAM module down.
When the RAM module is released carefully pull it out.
There is a second ram module under the first one.
Repeat Step 5 with lower Ram module.
取消:我没有完成这个指南。
与1其他贡献者
于09/18/18注册
580 声望
创作了5篇指南
徽章: 9
+ 6更多徽章
UNT-RAIGN-F18S3G6
4 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 822
