跳转到主内容
Lenovo IdeaPad Y410p Ram Replacement
你所需要的
  1. Lenovo IdeaPad Y410p Ram Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Ram Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Y410p Ram Replacement: 步骤 2 中的图像 2,2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Ram Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad Y410p Ram Replacement: 步骤 3 中的图像 2,2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Ram Replacement, Ram: 步骤 4 中的图像 1,3 Lenovo IdeaPad Y410p Ram Replacement, Ram: 步骤 4 中的图像 2,3 Lenovo IdeaPad Y410p Ram Replacement, Ram: 步骤 4 中的图像 3,3
    • Using the Phillips #0 screwdriver remove the eight 8mm screws that fasten the bottom cover.
    • Lift the bottom cover off using a metal spudger and set it aside.
  5. Lenovo IdeaPad Y410p Ram Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad Y410p Ram Replacement: 步骤 5 中的图像 2,2
    • Simultaneously pull apart both clips that are holding the RAM module down.
    • When the RAM module is released carefully pull it out.
  6. Lenovo IdeaPad Y410p Ram Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad Y410p Ram Replacement: 步骤 6 中的图像 2,2
    • There is a second ram module under the first one.
    • Repeat Step 5 with lower Ram module.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 858
