本指南有最近更改,您可查看未经巡查的最新版本。
简介
If the keys are not working, you can use this guide to replace the keyboard.
你所需要的
Use a metal spudger to loosen the frame of the keyboard by running it under the edges of the keyboard as shown.
After loosening the keyboard frame, you should be able to gently lift up the keyboard.
2等其他人完成本指南。
2条评论
Awful guide. Wish I'd seen the other comment before I also ruined my keyboard. Thought it popped out, but there's 2 screws under the bottom case that hold it (remove!) … bent the keyboard frame and ripped the screw tabs off. Was just trying to clean it. Now it needs total replacement.
How is this article reportable?
