当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using the Phillips #0 screwdriver, remove the eight 8mm screws that fasten the bottom cover.
Lift bottom cover off using a metal spudger and set it aside.
If you intend to reuse this hard drive, be careful removing it as hard impacts may damage the device.
Using the Phillips #0 screwdriver, remove the two 3mm screws at the end of the hard drive bracket.
Slide the hard drive out of its seat.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
