跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will help you replace your battery. Replacing the battery will fix any battery life issues caused by a faulty or corrupted battery. You can do it regardless of your technical knowledge or skill.
  1. Turn off your laptop before starting.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Slide the left battery lock to the unlock position and release. Slide the right battery lock to the unlock positon and hold it in place.
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside. While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
结论
Nick Torres
于2018年09月18日注册
559 信誉积分
创作了5篇指南
Change the wording on step 3. Also on step 2 change the red circles in the pictures to be bigger. We could not tell what was being circled and indicate the model stickers in step one. Add a new battery in “parts”.
Joseph McCoy - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 5
总计 170
