跳转到主内容
Lenovo IdeaPad U530 Touch Fan Replacement
你所需要的
  1. Lenovo IdeaPad U530 Touch Fan Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo IdeaPad U530 Touch Fan Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo IdeaPad U530 Touch Fan Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
    • Make sure to also remove the hinge screws.
  2. Lenovo IdeaPad U530 Touch Fan Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad U530 Touch Fan Replacement: 步骤 2 中的图像 2,2
    • To remove the panel, use a plastic opening tool to prevent any damage.
  3. Lenovo IdeaPad U530 Touch Fan Replacement: 步骤 3 中的图像 1,1
    • Locate and assess the battery. Pictured in the upper right area of the computer.
  4. Lenovo IdeaPad U530 Touch Fan Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad U530 Touch Fan Replacement: 步骤 4 中的图像 2,2
    • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
    • Be careful to keep track of all removed screws.
  5. Lenovo IdeaPad U530 Touch Fan Replacement: 步骤 5 中的图像 1,1
    • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
    • To remove the connection, please pull firmly, as it well secured.
  6. Lenovo IdeaPad U530 Touch Fan Replacement: 步骤 6 中的图像 1,1
    • Simply lift the battery out of the computer, and acquire a replacement.
  7. Lenovo IdeaPad U530 Touch Fan Replacement, Fan: 步骤 7 中的图像 1,3 Lenovo IdeaPad U530 Touch Fan Replacement, Fan: 步骤 7 中的图像 2,3 Lenovo IdeaPad U530 Touch Fan Replacement, Fan: 步骤 7 中的图像 3,3
    • Remove the six 3 mm screws from the fan using a JIS #1 screwdriver.
  8. Lenovo IdeaPad U530 Touch Fan Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaPad U530 Touch Fan Replacement: 步骤 8 中的图像 2,2
    • Disconnect the connecter cords from the fan and remove the fan.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 291
