跳转到主内容
Lenovo IdeaPad U450 Screen Replacement
你所需要的
  1. Lenovo IdeaPad U450 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Screen Replacement: 步骤 2 中的图像 1,1
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Screen Replacement: 步骤 3 中的图像 1,1
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Open the laptop.
  6. Lenovo IdeaPad U450 Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the four 7mm phillips head screws in the corners of the screen with a Phillips #00 Screwdriver.
  7. Lenovo IdeaPad U450 Screen Replacement: 步骤 7 中的图像 1,1
    • Pry the screen out of the tabs with a spudger.
  8. Lenovo IdeaPad U450 Screen Replacement: 步骤 8 中的图像 1,1
    • Remove the four 7mm phillips head screws located beneath the screen.
  9. Lenovo IdeaPad U450 Screen Replacement: 步骤 9 中的图像 1,1
    • Pop out the connector that links the screen to the motherboard.
  10. Lenovo IdeaPad U450 Screen Replacement: 步骤 10 中的图像 1,1
    • Pop the new screen into the connector.
结论
另外一个人完成了本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 216
