跳转到主内容
Lenovo IdeaPad U430 Touch Wifi Card Replacement
你所需要的
  1. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Wifi Card Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad U430 Touch Wifi Card Replacement: 步骤 3 中的图像 2,2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Wifi Card: 步骤 4 中的图像 1,1
    • Remove the two 2.8mm screws using the Phillips #0 screwdriver.
  4. Lenovo IdeaPad U430 Touch Wifi Card Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad U430 Touch Wifi Card Replacement: 步骤 5 中的图像 2,2
    • Remove the two snap cables connecting the wifi card to the rest of the computer.
  5. Lenovo IdeaPad U430 Touch Wifi Card Replacement: 步骤 6 中的图像 1,1
    • Slide the Wifi card away from the Wifi card connector.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 606
