跳转到主内容
Lenovo IdeaPad U430 Touch Speaker Replacement
你所需要的
  1. Lenovo IdeaPad U430 Touch Speaker Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Speaker Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad U430 Touch Speaker Replacement: 步骤 3 中的图像 2,2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Disconnect the speaker cable connectors from the motherboard and/or USB board.
  4. Lenovo IdeaPad U430 Touch Speaker Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad U430 Touch Speaker Replacement: 步骤 5 中的图像 2,2
    • Unscrew the two 6.5mm screws from each speaker with a PH1 Phillips head screwdriver.
  5. Lenovo IdeaPad U430 Touch Speaker Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad U430 Touch Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove and replace the speaker.
结论
Patrick Ripkey
于02/28/17注册
627 声望
创作了5篇指南
团队
USF Tampa, Team S2-G6, Nance Spring 2017 USF Tampa, Team S2-G6, Nance Spring 2017 的会员
USFT-NANCE-S17S2G6
3 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 567
