跳转到主内容
Lenovo IdeaPad U430 Touch Bottom Cover Removal
你所需要的
  1. Lenovo IdeaPad U430 Touch Bottom Cover Removal, Bottom Cover: 步骤 1 中的图像 1,1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Bottom Cover Removal: 步骤 3 中的图像 1,2 Lenovo IdeaPad U430 Touch Bottom Cover Removal: 步骤 3 中的图像 2,2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
结论
Patrick Ripkey
于02/28/17注册
627 声望
创作了5篇指南
团队
USF Tampa, Team S2-G6, Nance Spring 2017 USF Tampa, Team S2-G6, Nance Spring 2017 的会员
USFT-NANCE-S17S2G6
3 名成员
创作了15篇指南
一条评论
When removing the cover, be careful: There are a few (two or three?) plastic hooks that break easily in the area around the ports and the SD slot. (It's no big deal if they do break, but you can avoid it.)
Tom Janson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 2,957
