跳转到主内容
Lenovo IdeaPad U410 Screen Replacement
你所需要的
  1. Lenovo IdeaPad U410 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Lenovo IdeaPad U410 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Make sure your laptop is turned off before disassembling.
    • Power off the laptop.
    • Using the metal spudger, gently pry off the black trim around the screen.
    • Metal spudger can be used, but using your hand will prevent the screen and the plastic border from any damage.
  2. Lenovo IdeaPad U410 Screen Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad U410 Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the six 3 mm Phillips #1 screws holding the screen to the laptop.
    • Ignore the "Do not touch" label on the bottom portion of the screen. It will not damage the laptop.
  3. Lenovo IdeaPad U410 Screen Replacement: 步骤 3 中的图像 1,3 Lenovo IdeaPad U410 Screen Replacement: 步骤 3 中的图像 2,3 Lenovo IdeaPad U410 Screen Replacement: 步骤 3 中的图像 3,3
    • Lower LCD screen onto the keyboard.
    • Find the gold connector on the bottom of the LCD panel.
    • Gently grab the connector on both sides and pull the connector straight out.
    • Connector cable is very fragile. Use the least amount of force possible.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 32
总计 1,578
