跳转到主内容
Lenovo IdeaPad U410 Battery Replacement
你所需要的
  1. Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Battery Replacement: 步骤 2 中的图像 1,3 Lenovo IdeaPad U410 Battery Replacement: 步骤 2 中的图像 2,3 Lenovo IdeaPad U410 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Make sure your computer is turned off.
    • Lift the back panel away from you.
    • Locate the battery in the bottom right corner.
  4. Lenovo IdeaPad U410 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
  5. Lenovo IdeaPad U410 Battery Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad U410 Battery Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad U410 Battery Replacement: 步骤 5 中的图像 3,3
    • Locate the small rectangle shaped connector to the left of your battery.
    • Use your fingers to gently detach the white connector.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 910
