跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad U350 Keyboard Replacement
你所需要的
  1. Lenovo IdeaPad U350 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery by turning the laptop over.
    询问修复机器人
    添加评论
  2. Lenovo IdeaPad U350 Keyboard Replacement: 步骤 2 中的图像 1,3 Lenovo IdeaPad U350 Keyboard Replacement: 步骤 2 中的图像 2,3 Lenovo IdeaPad U350 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Locate the lock switch and slide toward the outside edge of the laptop until it clicks into place and the battery unit pops up.
    • Remove the battery unit from the laptop and set it aside.
    询问修复机器人
    添加评论
  3. Lenovo IdeaPad U350 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Unscrew the three screws on the bottom of the laptop that have small keyboard logos next to them using a PH1 screwdriver. These screws are 5.8mm long.
    询问修复机器人
    添加评论
  4. Lenovo IdeaPad U350 Keyboard Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad U350 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Flip the computer over and open the screen.
    • Use a spudger to carefully press in the clip that is found here while prying the keyboard upward from the same side.
    • This clip is very stiff and also made of thin, brittle plastic. This means that it is easy to break off, which is what we did during our disassembly.
    询问修复机器人
    添加评论
  5. Lenovo IdeaPad U350 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Slightly lift the bottom of the keyboard towards the screen to locate the keyboard's ribbon cable.
    • Use the tip of the spudger to lift the black retaining flap on the ZIF connector.
    • You should now be able to lift out the keyboard easily.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 1-4, Hickman Fall 2014 USF Tampa, Team 1-4, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G4
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 31
总计 2,056
