当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
These screws are attached to the panel. When unscrewing, be sure to stop when you here a click.
Slide the hard drive to the right, away from the RAM modules.
Lift the hard drive from the side closest to the RAM modules.
When re-inserting the hard drive, ensure that the copper contacts on the drive's connector are facing upwards.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
